Forums >> Revit Building >> Technical Support >> Creating Objects
8 Posts No Rating |
What is the best way to create my own objects that I want in Revit? Currently I've been experimenting with Inventor and importing the stuff I make in it to Revit but I just wanted to check to see if there was an easier or better way to do it?
what type of objects are you talking about. revit has the family editor for making components and the building maker tools for creating mass and in-place familys/objects.
8 Posts No Rating |
Well I was thinking about furniture mainly. I wanted to make my own beds, couches, chairs, etc.
well u can create furniture with the help of masses
Chirag C. Pawar Cad Solution Application Senior Engineer KLGSystel Ltd. India 301, Pujit Plaza, Plot No. 67,Sector 11, CBD Belapur,Navi Mumbai - 400614, Maharashtra, India.Tel .: +91 22 409 16777. Extn. - 718Fax .: +91 22 275 76461.Mob .: +91 99 698 66851.Email.: chiragp@klgsystel.com Web .: www.klgsystel.com |
If you want furniture that you can use in multiple projects, I'd make a new family. There are a couple of benefits to that, but the one I like most is that you can change the family remotely and then reload as needed. You can also turn the furniture on and off using your visibility/graphics. You can do that with masses too, but I find the set up to be a little less tedious if I just turn off all furniture families.
Ruth Rau Main Street Architecture, P.C. |
1 Posts No Rating |
I am creating a train station and want a light rail train that I invented in the program "Inventor." How do I import that train into Revit? Or further more, how do people create families?
You can export out of Inventor to the new .adsk format which is a valid family format inside of Revit. Can't remember if their is a plug-in that you need to download for this purpose in Inventor or not. You will also need to watch the orientation of the x,y and z axis inside Inventor as they differ from the standard Revit orientation. Check the Inventor help file for more information.
Creating objects |
Thu, Nov 16, 2006 at 6:06:59 PM
Creating new revit objects..... |
Sat, Apr 15, 2006 at 11:56:22 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects |
Fri, Oct 12, 2012 at 7:31:58 AM
please help- tried everything to get objects to accept material... |
Thu, Apr 16, 2009 at 12:45:04 AM
Creating Labels for Family Objects |
Wed, Nov 21, 2012 at 9:29:11 AM
Members: | 1990138 | Objects: | 22877 | Forum Posts: | 152180 | Job Listings: | 3 |
