172 Users Online (170 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Curved Beams?
Mon, Mar 3, 2008 at 7:23:24 PM | Curved Beams?
revitiw
Is there a way to create curved beams in revit architecture 2008?
Tue, Mar 4, 2008 at 2:30:33 AM | Curved Beams?
dianajohn
Why not create a sweep
Tue, Mar 4, 2008 at 10:32:39 AM | Curved Beams?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hey revitiw,
It is actually a pretty simple process.
Usualy what I do is create it as an in-place family. After a while, it might not be a bad idea to create it as a family to use in multiple projects but for now I'll tell you haw as an in-place.
The first thing I do is draw in where the curved beam is going to go using a detail line. Later this becomes the path for my sweep.
Then from the modeling design bar pick CREATE and this will pop up a dialog box that will ask what type of family you are creating...pick STRUCTURAL FRAMING.
Now look at your design bar, it should say FAMILY at the top...this is the in-place family editor.
From the design bar choose  SOLID FORM > SOLID SWEEP and this will bring into sketch mode allowing you to create your beam.
Next you need to asign the profile. This is done from the options bar on top. Instead of sketching the profile, hit the load option and browse to PROFILES > STRUCTURAL. Don't just double click on the wide flange as it uses a type catalog. Left click on what ever shape you want once, then select form the type catalog the actual size you need.
Next you have to define the path. This is why I drew in the detail line, now I can just use the PICK PATH option and select the detail line as my path otherwise just use the SKETH 2D PATHoption.
After you have the path you should now be able to finish out your in-place family.
HTH
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Curved Cell Beams
Thu, Dec 11, 2008 at 11:00:16 AM
Curved Beams
Mon, Jun 12, 2006 at 2:48:02 AM
Curved Beams
Sat, Nov 6, 2004 at 9:18:36 AM
Help with Steel I-Section Beams
Wed, Mar 3, 2004 at 7:13:07 AM
Curved Beams
Mon, Mar 2, 2009 at 9:16:43 AM
Page generation time: 1.2407
