154 Users Online (153 Members):
Forums >> Revit Building >> Technical Support >> Toggle on/off levels (and assoc. objects) in 3D view
20 Posts No Rating |
Using Revit 2008 here. Building a model for a 10 level high rise and since each level will be laid out differently, I was wondering if there was a way I could toggle on/off selected levels in my 3D view so I can see a specific level in 3D view for observation? I could not find a similar thread regarding this issue here in RevitCity nor do I fully understand setting up the filter options to get what I want. Maybe there is a workaround tip someone could share with me? And Revit veterans- if you feel this could be also posted on the wishlist- let me know and I would do so. Thanks!
If you set up each level as a workset, you could filter your 3d view accordingly. The problem would be the exterior facade. We like to keep that in a worset all of its own and you would not want that on. Still works pretty good for what you are wanting. Splitting the project up into these worsets will also help you with your overall speed and ease of use.
Combining objects that are on two separate levels at the same elevation |
Fri, Sep 25, 2009 at 10:20:23 AM
Drawing callouts disappearing when I toggle crop view |
Mon, Jun 18, 2007 at 11:14:46 PM
toggle annotation |
Wed, Feb 4, 2004 at 9:27:17 AM
why my levels have associated to objects, |
Fri, Nov 6, 2015 at 7:20:05 AM
Select All Objects by Referenced Level? |
Mon, Jun 5, 2006 at 5:14:28 PM
Members: | 1987187 | Objects: | 22874 | Forum Posts: | 152186 | Job Listings: | 3 |
