39 Users Online (38 Members):
Forums >> Community >> Newbies >> FROSTED CURTAIN WALL
i AM HAVING A HARD TIME FIGURING OUT HOW TO CREATE A NEW CURTAIN WALL THAT IS FROSTED... ALSO I HAVE TRIED TO INSERT CURTAIN WALL DOORS IN MY CURTAIN WALLS (AND THEY WILL NOT INSERT) ANY SUGGESTIONS?
Read the REVIT help for curtain walls.
THANKS FOR THE IMPUT, HOWEVER I HAD ALREADY FOLLOWED THE STEPS... FOR THE DOOR, IT SIMPLY TURNED EVERY PORTION OF CURTAIN WALL GLASS TO A DOOR, EVEN THOUGH I WANTED JUST ONE PANEL TO BE GLASS... DO YOU HAVE ANY BETTER SUGGESTIONS
Directly from the help ... - In a project view, create a curtain wall with panels. Size the curtain wall grid cells to the size of the curtain wall door or window you created.
- Load the curtain wall door or window family.
- Select a panel in the current wall. From the Type Selector, choose the family type you created to swap in the family.
For the frosted panel .... again from the help file... The Curtain Wall Panel family allows you to define a panel section that fits in a curtain wall grid. The panel actually resizes itself to fit in the grid. You define the appearance of the panel in different views: plan, elevation, 3D, and reflected ceiling plan. Typically, you define a 2D symbol to display in the plan view and 3D geometry to display in the elevation views and the 3D view. Before reading this topic, you should already have read Family Editor Basics.
Edited on: Mon, Feb 25, 2008 at 11:34:11 AM
how to change one 1 curtain wall material |
Fri, Sep 5, 2014 at 4:06:44 PM
How to change glass wall to a frosted design? |
Wed, Dec 15, 2010 at 5:52:33 PM
frosted glass with image cutout |
Fri, Sep 23, 2016 at 4:51:32 AM
frosted glass |
Wed, Jul 11, 2007 at 10:01:28 AM
I need a frosted glass material |
Tue, Aug 5, 2008 at 10:48:40 AM
Members: | 2000491 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
