40 Users Online (38 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> View to Freeze wall types
Sat, Feb 9, 2008 at 3:22:01 PM | View to Freeze wall types
SteveB
3.5 Stars: 5 Votes
to show a 3d isometric of the foundations only, would there be a way to display only a selected wall type & turn off all others in a 3d view?   I created a 3d view and hid all model categories except walls and used the iso section box in Element properties, but that isn't quite it because I have other wall types obscuring the fndtn.
Sun, Feb 10, 2008 at 12:08:18 PM | View to Freeze wall types
mthurnauer
3 Stars: 2 Votes
I am not in front of revit right not to test and see that this would work, but I think so.  Try picking one foundation wall and then right-clicking and and pick 'Select All Instances'.  I think this would pick all of your foundation walls.  You could then pick the option to Isolate Selected Items.
Sun, Feb 10, 2008 at 3:24:10 PM | View to Freeze wall types
NKramer
4 Stars: 9 Votes
Assuming that your foundation walls are drawn as structural elements you should be able to hide non- streuctural elements (other wall types).
Alternatly you could do what mthurnauer sugested. Although I would select all walls, hide elements, show hidden, find a foundation wall, select all instances, and unhide. But it basically does the same thing.
Nick
Freeze Drawings in 2012
Fri, Jan 11, 2013 at 9:12:42 AM
Freeze Proof Exterior Wall Faucet Component.
Mon, Jul 12, 2010 at 12:38:21 PM
How can I freeze groups?
Thu, Sep 21, 2006 at 10:06:39 AM
View Templates Not applying to view types
Mon, Nov 1, 2010 at 10:13:36 AM
How do I make custom wall types publicly accessible?
Sun, Apr 4, 2010 at 2:17:08 PM
Page generation time: 2.6620
