49 Users Online (48 Members):
Forums >> Revit Structure >> Technical Support >> View Title Line Thickness
16 Posts No Rating |
In the Revit Building >> Technical Support forum, Lizard 2806 offers the following to modify the view title line thickness... ...select the viewport title, then go into preferences, then click Edit/New. There you have the option of changing the line weight and line pattern... But I am unable to follow this since there are no preferences. In Revit Structure 2008, how does one control the title line thickness? Thanks.
Right click a view on a sheet and go to Properties. Then click Edit/New and you will see a parameter call Lineweight. Change it there. I believe Lizard2806 meant "Properties" instead of "Preferences"
Changing Line Thickness within a View Title Family... |
Fri, Jun 15, 2012 at 12:05:37 PM
Control Line in View Title Tag |
Mon, Jun 11, 2018 at 7:45:48 AM
View Title Extension line |
Mon, Apr 23, 2007 at 6:38:22 PM
Imported AutoCAD 2006 title block line thickness |
Thu, Sep 7, 2006 at 3:27:44 PM
Automatic View Title Extension Length |
Sun, Dec 18, 2016 at 5:45:56 PM
Members: | 1994690 | Objects: | 22882 | Forum Posts: | 152181 | Job Listings: | 3 |
