Tue, Oct 13, 2009 at 8:34:39 PM
Joined Mon, Oct 5, 2009
Is there anyway to join them together at the top?
Fri, Mar 19, 2010 at 8:04:12 PM
Joined Sun, Mar 14, 2010
is there?
Wed, Sep 29, 2010 at 10:25:24 AM
Joined Tue, Sep 28, 2010
same as here..is there any way to join them at the top
Thu, Sep 30, 2010 at 7:25:03 PM
Joined Wed, Aug 12, 2009 No rating This user is offline |
I will edit and repost. Sorry was my first family.
Thu, Sep 30, 2010 at 7:27:41 PM
When you say join at top?? Do you need it to attach to a elevation line? Please explain will happily adjust.
Sat, Feb 5, 2011 at 4:07:51 PM
Joined Thu, Jan 27, 2011
If I am not mistaken, I believe the poster is asking how to create a handrail at the top. When I load this family, this balister just appears as a balister. How would I connect them so there is one railing? Thank you!
Fri, Apr 19, 2013 at 9:48:35 AM
Joined Fri, Sep 14, 2012 No rating This user is offline |
Can these be used on stairs?
Wed, Feb 12, 2014 at 7:11:46 AM
Joined Wed, Nov 9, 2011
This look nice but unfortunately this was not created as a baluster family and it cannot be used on railing.
Mon, May 1, 2017 at 12:43:51 AM
Joined Sat, Jul 2, 2016 No rating This user is offline |
Buenisimo!!!! gracias!! lo unico que tienen que hacer para ponerle un pasamanos es crear un techo, con un desafase de altura de 0.68, lo dibujan con linea de contorno por encima de donde ubicaron los balustres. Espero les sirva, yo lo pude hacer perfecto!
Muchas gracias al creador!
Mon, May 1, 2017 at 12:46:22 AM
jajaja no se porque se escribio todo eso, crear un techo sobre los balustres, creen un desfase de techo de 0.68..
jajaja saludos!
Mon, May 1, 2017 at 12:46:41 AM
buehhh
Fri, May 17, 2019 at 3:31:29 PM
Joined Sun, May 12, 2019 No rating This user is offline |
excelenteeeee
Sat, Apr 24, 2021 at 2:47:23 AM
#13
Joined Sat, Apr 24, 2021
<3
